Clutch not disengaging
1996 SATURN SL1
130,000 MILES • 1.9L • 4 CYL • FWD • MANUAL
STACEY LEE SHAFOR
  • 4 POSTS
Replaced the clutch and the slave cylinder. the clutch is still not disengaging. please help.
Jul 20, 2017 at 3:51 PM
SATURNTECH9
  • 30,869 POSTS
Did you replace just the slave cylinder or the clutch master slave cylinder sealed assembly?
Jul 21, 2017 at 8:35 AM
STACEY LEE SHAFOR
  • 4 POSTS
We replaced the clutch, slave cylinder, and master cylinder. It was a combo kit.
Jul 22, 2017 at 6:18 PM
SATURNTECH9
  • 30,869 POSTS
So the new slave cylinder had a plastic clip to hold the shaft of the slave cylinder in place and straight when twisting it in place?Also when you put the clutch disc in the correct way?
Jul 22, 2017 at 6:24 PM
STACEY LEE SHAFOR
  • 4 POSTS
Yes, did all of that... we bled the slave cylinder after it wouldn't disengage... i've been going at this for 26 hrs... :(
Jul 22, 2017 at 6:30 PM
SATURNTECH9
  • 30,869 POSTS
So the clutch slave combo came as a one piece all hooked together?If so those aren't ment to bleed at all there plug and play.I have never needed to bleed one and have replaceda ton of them over the years.There is only a few reasons for the clutch not to disengage the clutch assembled incorrectly the slave cylinder installed incorrectly the clutch fork not seating correctly.Or a bad clutch master or slave cylinder is bad.
Jul 22, 2017 at 6:34 PM
STACEY LEE SHAFOR
  • 4 POSTS
Awesome, Thank you soo much. Will be back working on it in the morning and I'll let ya know what I figure out then. Take care!
Jul 22, 2017 at 6:39 PM
SATURNTECH9
  • 30,869 POSTS
Your welcome please let me know what you find.
Jul 22, 2017 at 6:40 PM
