Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Cavalier
Drivetrain
Transmission
Clutch
Symptoms
Disengage
Clutch not disengaging
2002 CHEVROLET CAVALIER
135,000 MILES • 2.2L
MITCHELLALAN
MEMBER
1 POST
FOLLOW
Replace clutch pressure plate an throw out bearing assembly. Bleed system to remove air. Pedal gets too hard to push down to relieve clutch.
Nov 26, 2017 at 3:22 PM
MHPAUTOS
CERTIFIED EXPERT
Did you check the through out bearing arm pivot? Is the slave cylinder getting full and free movement? can you check these?
Nov 27, 2017 at 9:19 PM
