Clutch issue
2002 MITSUBISHI LANCER
150,000 MILES • 4 CYL • 2WD • MANUAL
JOSH PROUDFOOT
I push the clutch to floor cannot get it in gear. Is it the throw-out bearing or do I just need to bleed clutch line?
Nov 2, 2017 at 10:17 AM
MHPAUTOS
  • 31,937 POSTS
If there is air in the system, there will be a leak and you will have to inspect both the master and slave, peel back the dust boots and check for fluid , the master boot is harder to access as it is under the dash.
Nov 2, 2017 at 11:55 PM
