Clutch is to the floor not engaged
1991 ISUZU RODEO
200,000 MILES • 3.2L • V6 • 4WD • MANUAL
DYL3733
My clutch is not working its to the floor with no pressure plz help. I drove it home speed shifting but it's parked now. It's a 91 Isuzu rodeo it's most likely a 91 clutch. So it might be due for me to replace it. I'm bout to loose my mind if I have to drop my tranny.
Jan 23, 2014 at 9:16 AM
SQM
  • 6,383 POSTS
This can be due to a faulty clutch master cylinder. Could also be due to air in the clutch system, also due to being low on fluid. And of course, the clutch could be just worn to a point that it is no longer engaging.
First make sure that the fluid level is correct.
I have attached the bleeding procedure below.
Thank you.
https://www.2carpros.com/articles/how-a-standard-transmission-works
Oct 17, 2021 at 10:58 PM
