Clutch pedal goes to the floor?
2003 FORD MUSTANG
125,000 MILES • V6 • 2WD • MANUAL
MERVEV
Recently while I was driving my car my clutch started to act weird while I was driving every day that passed as I drove it seemed to worsen there were noises as I pushed on the clutch even if it was just barely. and then the noise became a constant screeching at first it was only happening when I push the clutch pedal to shift but it got worse to where it was constant screeching noise no matter whether I had the clutch press or not. my question is, why is my clutch now down all the way to the ground and I could still lift it with my hand but it seems like it could be the cable, but I do not know a lot about a standard vehicle.
Aug 26, 2022 at 8:27 PM
GUANG
  • 0 POST
About Top Adult SEO
https://www.topadultseo.com
Aug 26, 2022 at 10:23 PM
I have seen the clutch secondary cylinder fail and make noise and not return the clutch pedal, also the clutch cable can be bad that's why we need to know where the noise is coming from. Here is a video of the clutch being replaced including the secondary cylinder:
https://youtu.be/JpzefqEeVGE
Here is how to change the clutch cable out i the images below:
This can help as well.
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Check out the instructions for the clutch cable below. Let us know what happens and please upload pictures or videos of the problem.
Aug 27, 2022 at 11:04 AM
