I just installed new clutch disc, pressure plate and slave cylinder. I pre-bled the slave cylinder prior to installing it.
My problem is the hydraulic line from the clutch master cylinder to the slave cylinder keeps popping out of the quick connect fitting at the slave cylinder, when under pressure, ie: when the clutch pedal is depressed. What are my options at this point? Thanks, Ken
Apr 20, 2020 at 4:57 AM
