The fan clutch operates based on engine compartment temperature. When the engine is cold, you should be able to turn the fan by hand. If you cannot, chances are you got a bad clutch. Take a look through this information. It discusses noise issues. See if they are what you are experiencing and let me know if it helps.
Fan Clutch Diagnosis
Fan Noise
Fan noise is sometimes evident under the following conditions:
^ When the clutch is engaged for maximum cooling.
^ During the first fifteen seconds to one minute after start-up until the clutch can redistribute the silicone fluid back to the fluid's normal disengaged operating condition (after overnight settling).
Fan noise, or an excessive roar, generally occurs continuously under all high engine speed conditions (2,500 RPM and up) if the clutch assembly locks up because of an internal failure. If you cannot rotate the fan by hand, or if there is a rough grating feel as the fan is turned, replace the clutch.
Looseness
Under various temperature conditions, a lateral movement is visible at the tip of the fan blade. About 6.5 mm (1/4 inch) maximum lateral movement, measured at the fan tip, is allowable. Replacement of the fan clutch is not necessary.
Ensure that the fan blade is installed properly. If the fan is installed incorrectly, the fan will cause an overheating problem.
I will watch for your reply.
Sep 18, 2018 at 7:19 PM
