That could cause the issue, you might want to try bleeding the system first.
Never use fluid which has been bled from a system to fill the reservoir. It may be aerated, have too high of a moisture content and possibly be contaminated.
1. Fill reservoir with new DOT 3 brake fluid, then press and hold down clutch pedal.
2. Open bleed screw on actuator cylinder to expel air, then close bleed screw and release clutch pedal.
3. Repeat procedure until all air is out of system, noting the following:
a. Check and refill reservoir as needed during bleeding so air is not drawn into system.
b. After bleeding, pump clutch pedal several times. If clutch engagement is not satisfactory, repeat bleeding procedure.
4. If this procedure is unsuccessful, perform the following:
a. Remove reservoir cap, then pump pedal very fast for 30.0 seconds.
b. Stop to let air escape.
c. Repeat as necessary.
Please let us know what you find.
Nov 2, 2022 at 2:56 PM
