Almost impossible to shift up or down or even reverse suddenly clutch to the floor?
2006 KIA OPTIMA
165,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
  • 34 POSTS
Clutch/cam shaft sensor?
Aug 5, 2023 at 9:31 PM
Does it shift normally with the engine off? If so and the pedal goes to the floor now, either we have a faulty clutch master cylinder, or the slave cylinder has failed.
Do me a favor. First, make sure the brake fluid is full. The brake master cylinder functions as the fluid reservoir for the clutch master cylinder (CMC). See pic below
Next, check around the CMC to see if there is any evidence of a leak. If you follow the supply tube to the transmission, it will lead to the slave (which I believe is internal on this vehicle). Check to see if there is evidence of fluid leaking in that area.
Let me know what you find.
See pic below. Note: I have the arrow pointing toward the brake MC. The circled item is the clutch MC.
Aug 5, 2023 at 11:37 PM
  • 34 POSTS
Thank you so much for getting back to me. sorry it's been such a long time before I got back to you, I'm just now able to look at my car and yes, it does shift regular in all gears with the ignition off l.
Aug 6, 2023 at 10:54 PM
No problem whatsoever. If it shifts normally with the engine off, then the transmission or shift linkage isn't an issue.
That leaves the clutch hydraulics. Were you able to check the things I mentioned?
Aug 7, 2023 at 1:02 PM
  • 34 POSTS
Yes, I did do some checking around those areas and from what I gathered and seeing I see no leakage anywhere.
Aug 8, 2023 at 11:54 AM
If that is the case, I suspect the clutch master cylinder is what failed. Not always, but often when the slave fails, they leak. Make sure the brake master cylinder is full.
As far as replacing the part, I attached the directions specific to this vehicle. Take a look through the directions and let me know if you have questions.
Take care and let me know what I can do to help.
See pics below. Note, the bleed procedure is included.
Aug 8, 2023 at 9:33 PM
  • 34 POSTS
Thank you so much, I'll be in touch.
Aug 9, 2023 at 12:43 AM
You are very welcome. If you have questions, let me know.
Aug 9, 2023 at 8:52 PM
