Hello, my gear stick is really loose and wobbles alot and my clutch is really hard to push and springs straight back up.
Jun 14, 2016 at 3:55 PM
CERTIFIED EXPERT
It sounds like you have two problem, the first is the stick shifter, at the bottom of the stick part there is a plastic ball and yours has falling apart and need replacing, remove the stick housing from on top of the transmission and replace the bushing. The second part is the clutch itself is worn out and the pressure plate is past its pivot point creating the hard pedal you describe for this the transmission with need to be removed, here is a guide to let you know what you are in for.
