Clutch and gear stick
1999 PEUGEOT 206
104,000 MILES • 1.6L • MANUAL
BETHANIE03
Hello, my gear stick is really loose and wobbles alot and my clutch is really hard to push and springs straight back up.
Jun 14, 2016 at 3:55 PM
It sounds like you have two problem, the first is the stick shifter, at the bottom of the stick part there is a plastic ball and yours has falling apart and need replacing, remove the stick housing from on top of the transmission and replace the bushing. The second part is the clutch itself is worn out and the pressure plate is past its pivot point creating the hard pedal you describe for this the transmission with need to be removed, here is a guide to let you know what you are in for.
https://www.2carpros.com/articles/transmission-replacement-removal-manual
Let me know how it goes
Best, Ken
Jun 17, 2016 at 8:33 AM
BETHANIE03
Thank you will order a new clutch do you no what the thing is called for the gear stick please as I can't find anything.
Jun 17, 2016 at 12:47 PM
It could be a ear shifter bushing, every manufacturer calls is something different, pleas come back with the proper name once you contact the dealer.
Jun 17, 2016 at 2:44 PM
