Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Mustang
Drivetrain
Transmission
Gear Selector
Stuck
After installing a new clutch the shifter popped out of gear and the car did not move?
2006 FORD MUSTANG
82,000 MILES • V6 • 2WD • MANUAL
LURKZ
MEMBER
FOLLOW
I recently installed a new clutch two weeks ago. As I was driving the shifter popped out of gear and the car did not move ...
Mar 23, 2023 at 3:03 PM
CERTIFIED EXPERT
Are you unable to get it back in gear? Also, does the shift linkage feel like it has the same tension as it did prior to this happening?
Will the transmission shift with the engine off?
Mar 23, 2023 at 6:38 PM
LURKZ
MEMBER
I can put it in gear but when I accelerate the car just revs, like if it was on neutral.
Mar 24, 2023 at 3:14 AM
CERTIFIED EXPERT
Is there any noise when you release the clutch? It sounds like the pressure plate has failed. Also, make sure the driveshaft is connected.
Mar 24, 2023 at 10:00 PM
