Put a new clutch pressure plate throw out bearing slave cylinder it has a stiff pedal. when not running then when you start it has only a little pedal and it will not go in gear but when you turn it off it will go into a gear. Maybe master cylinder? What do you think? Thanks
Sep 11, 2024 at 1:12 AM
