Good morning.
You have both clutch maser cylinder and a clutch slave cylinder that may be leaking.
Whichever one is leaking, it is suggested to replace both at the same time.
Master cylinder
Removal
1. Remove the flexible hose (A) from the brake reserve tank.
imageZoom/Print
2. After pulling out a clip, disconnect the clutch tube (B) from the master cylinder.
3. Disconnect the ignition lock switch connector (A).
imageZoom/Print
4. Remove the push rod from the clutch pedal by removing the snap pin (A) and washer (B).
imageZoom/Print
5. Remove the clutch pedal mounting nut (C-3ea).
6. Remove the clutch pedal bracket mounting nut (A-2ea).
imageZoom/Print
7. Remove the clutch master cylinder from the clutch pedal assembly by rotating the clutch master cylinder 45 degree counter clockwise.
slave.
to replace the slave cylinder, the transmission must be removed.
Removal
1. Remove the transaxle assembly.
2. Remove the C.S.C assembly (B) from the transaxle case by removing bolts (A-3ea).
imageZoom/Print
Are you planning on repairing this yourself?
Jun 6, 2018 at 7:24 AM
