Clutch
1988 HOLDEN COMMODORE
100 MILES • 3.0L • 6 CYL • RWD • MANUAL
SHAWNOS
I changed the clutch on my VL Commodore. 5 speed manual. I put in new clutch and pressure plate, tightened gearbox and went to bleed clutch, but there is no clutch. At first there was a real little bit then when I released it it would not pump up, so I can continue to bleed it. I tried with a friend to pump adn pump the peddle, but there was nothing to pump up. Please help! I did the replacement on the weekend and I need my car for work. Thank you heaps if you can help.
Mar 12, 2016 at 2:25 AM
MHPAUTOS
  • 31,937 POSTS
try gravity bleed, open slave bleeder and keep master filled and allow fluid to run for a bit, close bleeder and if you get pedal pressure do a pressure bleed as well.
Mar 12, 2016 at 4:20 AM
