Clutch?
2002 TOYOTA MR2
100,000 MILES • 4 CYL • MANUAL
MCCOY_KATHY
Clutch 'whines' when not engaged, yet is silent when depressed. I cannot shift into gears easily at all. When I do get it into 1st or 2nd, my car runs beautifully until some to shift again. It will not go into other gears.
Apr 3, 2016 at 12:04 PM
HMAC300
  • 48,601 POSTS
check fluid level in reservoir make sure it is full. the whine may be a bad pilot bearing in end of crank. check cables at trans may be out of adjustment ,broken or frayed not allowing you to other gears . try shifting to other gears with engine off is still won't go disconnect cables and see if it will that will tell you it's a cable problem .they can be broken at trans or shifter as well as shifter worn out.
Apr 3, 2016 at 12:38 PM
MCCOY_KATHY
Thank you so very much! YOU ROCK! Gonna have my sweet hubby check all the suggestions as soon as Sun's up.
Apr 3, 2016 at 9:17 PM
