Okay, thanks for that information.
Since you report the fluid is full then one of the following is not allowing the clutch disc to move enough to release completely.
1. You may have air in the system somewhere in which case you would need to bleed the system. See the link below for instruction on how to do that.
2. The slave cylinder seals are worn and leaking. I think we can rule this out since you say the fluid level is full, unless you have filled it yourself.
3. The clutch Master Cylinder seals are worn and allowing fluid to blow past the piston seals. This would require the replacement of the Master Cylinder.
4. The clutch release lever inside the bell-housing is damaged (bent or cracked). This is rare, but it does happen. In this case the lever would need to be replaced.
Regards
Jon
Mar 24, 2021 at 11:26 AM
