Did you check the clutch fluid in the clutch master cylinder?
I attached the procedure for the slave cylinder on the bell housing. That is a common failure for this issue.
Removal and Installation
REMOVAL
1. Drain clutch fluid.
CAUTION: Do not spill clutch fluid onto painted surfaces. If it spills, wipe up immediately and wash the affected area with water.
2. Remove clutch hose from operating cylinder.
3. Remove operating cylinder mounting bolts and then remove operating cylinder from vehicle.
INSTALLATION
To install, reverse the removal procedure, following the cautions below:
^ Install hose with care so that it will not be bent or twisted.
^ After completing the procedure, bleed clutch hydraulic system.
Mar 15, 2019 at 6:21 PM
