whirling sound when I press the clutch
2001 SUZUKI ESTEEM
147,403 MILES • 1.6L • 4 CYL • 2WD • MANUAL
RAECHELE OSBORN
When I press on clutch it makes a whirling sound, it is hard to put in gear. Does it mean new clutch or can I just have the bearing replaced?
Mar 11, 2017 at 4:06 PM
MHPAUTOS
  • 31,937 POSTS
The thrust bearing is probably failing. it is always good to go with a new clutch and the work involved is just the same and you do not want to be pulling the transmission again in the near future if the clutch starts to slip. there is a good chance that the clutch as well due for replacement anyway. also, make sure that you get the fly wheel re surfaced and replace the spigot bearing in the back of the flywheel. do it all now and you w ill not have a problem for years as far as the clutch is concerned.
Mar 11, 2017 at 4:18 PM
