Clutch, car revs but does not move
2003 DODGE NEON
102,000 MILES • 2.0L • 4 CYL • FWD
CALIBLUEYEZ
My car revs up but does not go anywhere it seems like it is in gear but does not stall out when foot is off the clutch. Shifter also became lose before this happened.
May 8, 2017 at 9:25 AM
HMAC300
  • 48,601 POSTS
have someone help you and see if transmission is actually shifting it may be a broken cable or linkage or shifter worn out. then have them press clutch at same time engine does not need to be running. if shifter is not working then it is kind of see able what is happening. if not the clutch may be the culprit or the hydraulics are not working for clutch and arm is not going in and out.
May 8, 2017 at 9:38 AM
CALIBLUEYEZ
I havent had anyone look at my car, I dont have the money for a mechanic I have been trying to trouble shoot this the cheapest way possible.
May 11, 2017 at 12:19 PM
HMAC300
  • 48,601 POSTS
the reply that I sent you most of the stuff you can do without a mechanic its looking at what goes on.
May 11, 2017 at 1:27 PM
CALIBLUEYEZ
My clutch reservoir needs to be replaced because the hose on the bottom broke where can I buy one at
May 16, 2017 at 7:33 PM
HMAC300
  • 48,601 POSTS
auto parts store should have those
May 17, 2017 at 6:33 AM
