Cluster lights going off and no speedometer car will not start?
2013 FORD FLEX
180,000 MILES
SHWAGR
Was driving and had a bunch of warning lights all of a sudden come on then the speedometer dropped to zero. the car drove fine and made it home no issue but when I went to leave next morning the car would not start or turn over.
Jan 23, 2025 at 3:07 PM
It sounds like a module has gone out or something shorted and popped a fuse. Let start by doing a fuse check (systems on). this guide can help you with the fuse locations in the images below:
If the fuses are all good and have power let's do a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
To me it sounds like the BCM might have gone bad, but we need more information to be sure.
Jan 24, 2025 at 10:48 AM
