Clunking noise when I accelerate
2002 MERCEDES BENZ ML500
130,000 MILES • V6 • 4WD • AUTOMATIC
BECKYSPAGE
Having a hard time with tires blowing out so I've been driving on a donut. last night when I got up to 5 MPH a horrible clunking noise started and felt like tires were going to fall off.
Mar 11, 2021 at 4:37 PM
Can you get a recording of the noise? That will help identify what the issue is.
Also, here is a guide that will help with different noises. I am not sure this issue is covered in here but without hearing the noise, it is hard to know.
https://www.2carpros.com/articles/engine-noises
I suspect this is a loose wheel or tire as they will make all sorts of noise when they are turning but does this make a repeated thumping noise or is it only at certain times?
Again a video will most likely answer most all questions. Thanks
Mar 12, 2021 at 4:38 PM
