Clunking Noise
2007 HONDA CITY
85,000 MILES • 1.5L • 4 CYL • FWD • AUTOMATIC
SEAN92
  • 18 POSTS
Whenever I slow down to around one to ten mph and than tap the accelerator I hear and feel a clunking on the driver's side part of the engine bay. It does not do this all the time. I am wondering if the bushings in the control arm could be causing this? 1.8L engine
Jan 30, 2017 at 10:59 AM
HMAC300
  • 48,601 POSTS
Could be that or axles have front suspension or an engine mount. Could be a ball joint as well.
Jan 30, 2017 at 12:09 PM
SEAN92
  • 18 POSTS
Thank you, I will have it looked at.
Jan 30, 2017 at 12:55 PM
SEAN92
  • 18 POSTS
This is what a normal hole for the upper dog bone motor mount looks like(circled in red),the hole in my car looks like a stretched out circle(oval). If that's the case does anyone know if that's part of the frame and the only way to fix it is to replace that metal part of the frame?
Feb 1, 2017 at 5:13 AM
SEAN92
  • 18 POSTS
This is what mine looks like, finally just took the mount off for a picture
Feb 1, 2017 at 6:57 AM
Hey SEAN92
That is what it should look like, make sure the bolt is tight and you should be fine, if the bolt was loose it would make the noise you were talking about.
Please let us know what happens so it will help others
Best, Ken
Feb 6, 2017 at 2:04 AM
SEAN92
  • 18 POSTS
The problem was a cracked bushing on the front left lower control arm.
Feb 11, 2017 at 7:46 PM
MHPAUTOS
  • 31,937 POSTS
Thanks for the feed back, this may be a help to others, thank you for using 2carpros.
Feb 12, 2017 at 3:12 AM
