Clunking during low speed turns
1992 NISSAN 240SX
316,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
FLYGIRL
Clunking noise during turn around mainly when in reverse, backing out of or parallel parking.
Catalytic converter is rattling. I want to take it off.
0bd1. Old car 1992. Any suggestions?
Nov 19, 2019 at 7:43 AM
SCGRANTURISMO
  • 4,897 POSTS
If your Catalytic converter is rattling and you want to take it off, simply cut it off with a saws all and you can get a sleeve to slip on in place of the cat with woven steel braid on Amazon or Ebay for a reasonable price. Clamp it in place with muffler clamps, again inexpensive on Amazon or Ebay. Just make sure you get the same diameter as the exhaust on your vehicle. Clunking when turning is usually a sign of a bad CV joint. Here is are a couple of guides explaining what's going on and how to replace it below:
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
https://www.2carpros.com/articles/replace-cv-axle
Please go through these guides and get back to us with what you are able to find out, and/or how everything turns out.
Thanks,
Alex
2CarPros
Nov 19, 2019 at 7:51 AM
