I changed an upper ball joint on my vehicle listed above thinking that was the source of a clunking sound while driving over bumps. I changed all brakes and rotors, everything is torqued to specs. I checked the hub bearing by grabbing the tire at the 3:00 and 9:00 position. It moves about a half inch. At the 12:00 and 6:00 position it does not move. No slack (play) in anything. Only in the 6:00 and 12:00 position. I am thinking the hub bearing is the culprit. If your thoughts are the same as mine, could you give me the torque specs for the hub assembly and the axle nut? This will avoid me having to ask you for it. Other suspension parts do not have any slack in them at all. It sounds like it's coming from the front passenger side. That's where I changed the upper ball joint.
Apr 6, 2021 at 6:27 AM
