I recently changed the front brakes and rotors on my truck listed above 1500. I had a worn hub bearing so I replaced it as well. Ever since these parts have been changed, when I apply the brakes, a clunking sound comes from passenger side front. I didn't torque the hub bearing because I couldn't find the torque specs for it. I don't hear the noise unless going at real slow speed when applying brakes. If a tie rod end or ball joint or control arm bushing would be worn. It seems like I'd hear it when I run over a bump or a pothole. Which I don't. So what do you think is doing this? If you have the torque specs for brake guide pins and hub bearing, I can torque them to see if that solves the problem. Thanks for your help.
Oct 1, 2020 at 6:17 PM
