Hi Rey,
I got a head set for my computer, Now I can hear a lot better, I should have done this a while ago, lol. But anyway, Yes I can hear what your speaking of i believe. Not really a clunking thing but more a clicking sound. I have hear this type of sound from transmissions when I've had a car on the lift with the tire spinning then accidentally putting it into park without using the brakes to stop the wheels from spinning before going into park.For that its the park lock pin not getting into place because the wheels were turning. Yours is a transaxle and it might be getting stuck between to modes. To me it sounds like your transmission isn't getting fully out of the drive gear before going into the reverse gear and we're hear the splines on an internal shaft slipping by its locking mechanism till it full engages. Almost like a solenoid isn't fully engaging or disengaging. Will the sound happen when your going from park at idle to reverse or does it happen only when you've been in drive then going to reverse? Pull out your transaxle dip stick and inspect the oil on it, is it red or black? It should be red and fairly clear. Smell it also to see if it smells burnt as well.
There happens to be a technical Service Bullitin that is kind of like what your hearing. Here is what they are saying about it.
TBS from Dodge
SYMPTOM/CONDITION:
A "racheting" or clicking sound is heard during garage shifts or when the vehicle is coming to a stop. This sound is normal and is associated with the operation of the transaxle shift solenoid. On some vehicles this sound may be more noticeable than others because of variations in sealing of the solenoid sound shield. THE TRANSAXLE SHIFT SOLENOID SHOULD NOT BE REPLACED FOR THIS CONDITION.
DIAGNOSIS:
With the vehicle operator present, confirm the sound is associated with the transaxle shift solenoid operation by firmly applying the brakes then, while the engine is running, shift the vehicle into gear. If the racheting sound is confirmed, perform the Repair Procedure.
If this sounds like whats happening then here is what they are saying:
PARTS REQUIRED:
AR 82300234 Sealant, Mopar RTV
REPAIR PROCEDURE:
This bulletin involves sealing ALL air gaps between the solenoid sound shield and the transaxle case.
NOTE:
THIS REPAIR PROCEDURE WILL NOT ELIMINATE THE RACHETING SOUND BUT WILL REDUCE IT AS MUCH AS POSSIBLE. THE RATCHETING SOUND IS A NORMAL CHARACTERISTIC OF THIS TRANSAXLE AND IN NO WAY EFFECTS THE RELIABILITY OR DURABILITY OF THE TRANSAXLE.
1. Clean the area where the solenoid sound shield meets with the transaxle case with steam or other appropriate cleaner. Raising the vehicle on an appropriate hoist and/or removing the air cleaner may be helpful in gaining access to the area.
NOTE:
DO NOT use petroleum based cleaners because they may deteriorate the sound shield and/or the electrical connectors/components.
2. Blow the area dry with compressed air.
3. Use Mopar RTV sealant (P/N 82300234) to seal ALL air gaps between the solenoid sound shield and the transaxle case.
4. Lower the vehicle and install the air cleaner if applicable.
POLICY: Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No: 21-90-95-90 0.3 Hrs. FAILURE CODE: XX - Service Adjustment
Let us know if we are on the right track with this
Tom
Aug 10, 2020 at 9:34 PM
