I assume you are talking about the bump stops that when a strut or shock fail it prevents the spring from bottoming out?
If this is the case then yes, there is a rubber stop inside the strut in most cases. While I have not looked inside this vehicles spring they are all pretty much the same.
However, if you have a clunking only when hitting a bump then I suspect the spring has failed but does this corner of the vehicle drop down or is it still holding the proper height?
If it is not dropped then the air bag is not likely the issue. More than likely you have a ball joint issue or other suspension issue.
However, I will attaching the info needed to replace this.
Here is a video on a different vehicle but it will be similar:
https://youtu.be/tXnyEEFlFnA
Below is the process from the manual on how to replace this and test it.
Please run through this and let us know if you have other questions and what you find.
Thanks
Sep 2, 2021 at 6:36 PM
