Climate Control Vacuum Lines
2010 FORD RANGER
108,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
CLP2005CLP
I am unable to change the direction of airflow in the cab from the defroster/floor setting. I found a vacuum line coming from the reservoir not connected to anything. Can you tell me where this line should be connected? Thanks in advance.
May 17, 2016 at 3:50 PM
HMAC300
  • 48,601 POSTS
it probably goes to a vacuum motor by driver side. Check where this one is and see if it is disconnected.
http://www2.prodemand.com/img/G06182588
May 17, 2016 at 4:38 PM
