Climate control not working
2000 MITSUBISHI DIAMANTE
125,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
KEVIN BROWN2
i installed an aftermarket stereo and climate control quit working. i found out it requires an amp kit and the factory amp controls the climate control. i put the factory stereo back in but my climate control still will not work.
Feb 11, 2018 at 12:37 PM
KHLOW2008
  • 41,814 POSTS
Hi Kevin,
Did you check for blown fuses? During removal/installation something could have gone wrong causing the fuses to blow. Next to check would be the wire harness and grounding points. Ensure connectors are plugged together securely.
Feb 13, 2018 at 1:35 AM
