Climate control lights out
2009 CHEVROLET IMPALA
107,000 MILES • 3.5L • V6 • FWD • AUTOMATIC
JOSHUA STEVENS
  • 11 POSTS
Hello, my climate control lights are out and i cannot find any information if this could be a fuse or just the bulbs. I also read somewhere that i might have to replace the whole climate control component. Can you help?
Jun 11, 2016 at 10:10 PM
WRENCHTECH
  • 20,761 POSTS
That most likely uses an LCD display that no longer works. That would mean replacing the whole control head.
Jun 12, 2016 at 5:34 AM
JOSHUA STEVENS
  • 11 POSTS
found out it was 15a fuse that was blown. My question now is it keeps blowing is there a place i can get a free schematic/wiring diagram of the int panel/dimmer circuit?
Jun 13, 2016 at 12:58 PM
WRENCHTECH
  • 20,761 POSTS
https://www.2carpros.com/images/external/155623454.gif
Jun 13, 2016 at 1:23 PM
JOSHUA STEVENS
  • 11 POSTS
Thank you. I am really confused though because in my car the only thing that 15a fuse controls that i can tell is the lights on climate control and the trunk light.. the trunk light i dont even see on there. Am I looking at this wrong?
Jun 13, 2016 at 5:48 PM
WRENCHTECH
  • 20,761 POSTS
You asked for the diagram for the dash light circuit. What you really needed was the diagram for that particular fuse.
Jun 13, 2016 at 5:51 PM
JOSHUA STEVENS
  • 11 POSTS
sorry I thought that was what i needed
Jun 13, 2016 at 5:58 PM
WRENCHTECH
  • 20,761 POSTS
Give me the fuse name or number and the location.
Jun 13, 2016 at 6:00 PM
JOSHUA STEVENS
  • 11 POSTS
15a interior lights and panel dimmer...
Jun 13, 2016 at 6:05 PM
WRENCHTECH
  • 20,761 POSTS
That feed goes directly to the BCM and it takes it from there. Going to be hard to track. https://www.2carpros.com/images/external/216861006.gif
Jun 13, 2016 at 6:16 PM
JOSHUA STEVENS
  • 11 POSTS
So basically I'll have to manually track the short down? Do you know a rough estimate to get a mechanic to do this? I dont have the patience for all that.
Jun 13, 2016 at 6:23 PM
WRENCHTECH
  • 20,761 POSTS
They would work by the hour, usually at about $120 per hour around here. Make sure he's an electrical specialist though. Most general techs would struggle with this. They have no path to follow.
Jun 13, 2016 at 6:29 PM
JOSHUA STEVENS
  • 11 POSTS
any chance you have the wiring diagram for the trunk light? Its grounded after the climate control lights and before the trunk light. I appreciate all your help btw.
Jun 13, 2016 at 6:35 PM
WRENCHTECH
  • 20,761 POSTS
There is no before and after. They are wired in parallel. the short could be from anything the BCM operates. If you suspect something, just unplug it and see if the fuse blows.
Jun 13, 2016 at 6:43 PM
JOSHUA STEVENS
  • 11 POSTS
Oh, ok. Thank you. I will post what I find when I figure it out. Thanks again for the information.
Jun 13, 2016 at 6:47 PM
JOSHUA STEVENS
  • 11 POSTS
i got an ect2000 to track down the short and discovered it is on the orange wire of my dome light. I have some diagrams of the interior lights but I'm having a hard time reading them and i dont know which plug in the bcm they are connected to. All it says is X2/1 i get that that is connection 2 pin 1 but which is connection 2? can you help me with this?
Jul 13, 2016 at 7:59 PM
WRENCHTECH
  • 20,761 POSTS
http://i1198.photobucket.com/albums/aa448/Wrenchtech/143364886.gif https://www.2carpros.com/images/external/143369571.gif
Jul 14, 2016 at 2:26 AM
JOSHUA STEVENS
  • 11 POSTS
Thank you for that. The wire I'm trying to trace is orange. I dont see an orange on there. Is there a splice somewhere that changes the wire color?
Jul 14, 2016 at 7:07 PM
WRENCHTECH
  • 20,761 POSTS
https://www.2carpros.com/images/external/156525371.gif
Jul 14, 2016 at 7:13 PM
JOSHUA STEVENS
  • 11 POSTS
that's the diagram i have. Do the connections go in order on bcm? like you showed me x1 and it is lt gn so x2 would be the next one upso it would be a white connection? I need to isolate the circuit from the bcm and run further diagnostics to find the short to ground.
Jul 14, 2016 at 7:21 PM
WRENCHTECH
  • 20,761 POSTS
http://i1198.photobucket.com/albums/aa448/Wrenchtech/78487904.gif https://www.2carpros.com/images/external/78487905.gif
Jul 14, 2016 at 7:29 PM
JOSHUA STEVENS
  • 11 POSTS
So it's the pink connector? Is that right? My pink connector has quite a few more wires in it. Like a black and gray for constant power to the dome light? is this just the specific wires of what I asked for? Thank you for all your help.
Jul 14, 2016 at 7:37 PM
It does not show the connector color, you we need to follow the color wire. Nice work Wrenchtech!
Jul 17, 2016 at 8:43 AM
