Climate control issues
2001 MAZDA 626
54,000 MILES • 4 CYL • 2WD • AUTOMATIC
I got this car from my aunt. It sat for a year, due to this the battery drained and I replaced it. The air conditioning works wonders and blows out really cold air. The heat also works. But when I try to select a different vent selection (other then head/front) the led light changes to the right button, but air continues to blow out the head/main vents. I usually would not care, but I need to have air go through the defroster vents. What could cause this ?
Jun 27, 2017 at 9:23 AM
It sounds like the blend door actuator has gone bad, here is a guide that will give you an idea on how to fix the problem.
Here are some diagrams (Below) on your car.
Jun 29, 2017 at 10:58 AM
We fixed it. There was a connector unplugged
Jun 29, 2017 at 1:40 PM
Nice work, we are here to help, please use 2CarPros anytime. Which connector can you upload an image please?
Jun 30, 2017 at 10:25 AM
