Climate Control blower
1994 BUICK ROADMASTER
182,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
LITTLESISTER582
My car has climate control for air, vent and heat. When I turn the system on, the screen on the dash shows the fan working at the designated speed based on the temperature in the car; however, there is no air blowing out the vents. I have checked the fuse for the blower in my fuse box and it looked fine. I then replaced the fuse with a new one. I still have no air coming out the vents. Is this a blower problem, fan problem, or possible wiring from fuse to system?
Sep 26, 2016 at 10:21 PM
AL514
  • 5,465 POSTS
check for power at the blower motor itself. it should be under the right side of the dash board. you can use a regular test light, its a 12volt circuit. Let us know what you find.
Sep 27, 2016 at 1:53 AM
