Welcome to 2CarPros.
I'm not sure I understand. What has the new switch replaced? As far as the temperature issue, the vehicle has a blend air door actuator. It is an small electric motor that moved the temp door to different positions to provide different tempertures.
Can you explain the switch that was replaced? Also, I am going to provide the directions for actuator replacement. Locate the actuator and see if anything has been done to it. Also, see if it working when you try to change temperatures.
________________________________________
Here is a link that shows in general how one is replaced:
Here are the directions specific to your vehicle. The attached pictures correlate with the directions.
2006 Jeep Truck Grand Cherokee 4WD V6-3.7L VIN K
Single Zone/Dual Zone LH Side
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Procedures Blend Door Actuator Single Zone/Dual Zone LH Side
SINGLE ZONE/DUAL ZONE LH SIDE
NOTE: The single zone heater - A/C system is equipped with a single blend door actuator. The dual zone system has two blend door actuators, one for the driver side blend - air door and one for the passenger side blend - air door.
REMOVAL
WARNING: ON VEHICLES EQUIPPED WITH AIRBAGS, DISABLE THE AIRBAG SYSTEM BEFORE ATTEMPTING ANY STEERING WHEEL, STEERING COLUMN, OR INSTRUMENT PANEL COMPONENT DIAGNOSIS OR SERVICE. DISCONNECT AND ISOLATE THE NEGATIVE BATTERY (GROUND) CABLE, THEN WAIT TWO MINUTES FOR THE AIRBAG SYSTEM CAPACITOR TO DISCHARGE BEFORE PERFORMING FURTHER DIAGNOSIS OR SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE THE AIRBAG SYSTEM. FAILURE TO TAKE THE PROPER PRECAUTIONS COULD RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY OR DEATH. See: Air Bag(s) Arming and Disarming > Service and Repair
pic 1
1. Disconnect and isolate the negative battery cable. See: Battery Cable > Service and Repair
2. On LHD models, remove the instrument panel silencer from the driver side of the instrument panel.
3. On RHD models, remove the glove box from the instrument panel.
4. Remove the three screws (1) that secure the blend door actuator (2) to the left side of the HVAC air distribution housing (3).
5. Remove the blend door actuator from the air distribution housing and disconnect the HVAC wire harness connector (4) from the actuator.
6. Remove the blend door actuator from the vehicle.
INSTALLATION
pic 2
1. Position the blend door actuator (1) into the vehicle.
2. Install the blend door actuator onto the left side of the HVAC air distribution housing (2). If necessary, rotate the actuator slightly to align the splines on the actuator output shaft (3) with those on the blend door cam (4).
pic 3
3. Install the screws (1) that secure the blend door actuator (2) to the left side of the air distribution housing (3). Tighten the screws to 2 N.m (17 in. lbs.).
4. Connect the HVAC wire harness connector (4) to the blend door actuator.
5. On LHD models, install the instrument panel silencer onto the driver side of the instrument panel.
6. On RHD models, install the glove box into the instrument panel.
7. Reconnect the negative battery cable.
Let me know if this helps.
Dec 9, 2020 at 3:43 PM
(Merged)
