Climate control stopped working
2002 DODGE DURANGO
150,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
ERIC 72
Yesterday the temperature control was working fine and today I can't control drivers side or passengers side. Checked fuses in the inside fuse block bit none are blown. Looking for troubleshooting advice.
Jan 1, 2020 at 1:24 PM
Do you mean there is no heat or have you lost air flow direction?
If you lost heat, first make sure the engine coolant is full. Take a look through this link and let me know if it helps. If it doesn't, we'll move on to checking other things.
https://www.2carpros.com/articles/car-heater-not-working
If it is heat that you lost, and you lost it to both sides of the dual climate system, my first suspect is low coolant or a plugged heater core, so let me know what is going on.
Jan 1, 2020 at 8:29 PM
