HVAC does not want to blow heat in winter and does not blow cold air in the summer?
2004 MAZDA RX8
89,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
MICAHMIZE
I try to use my A/C and heat and the fan blows but only blows in the temperature that’s outside. It’s like it doesn’t want to blow heat in winter and doesn’t want to blow air in the summer. It gets annoying and my glass stays fogged up because I get no heat in the winter.
Nov 10, 2022 at 10:19 PM
This happens when the air mix door actuator stops working. here is the location and how to replace it in the images below. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Nov 11, 2022 at 10:56 AM
