Climate control
1999 PLYMOUTH GRAND VOYAGER
359,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
DARLENE MCKELLAR MOOTISPAW
Wanting to reset my actuator and or blend door in my van, but reading some answers on here it says to remove fuse with key on for sixty seconds. But didn't say which fuse to pull?
Jan 7, 2019 at 4:16 PM
Good evening,
The calibration is below for your van.
It is a little different than what we stated. most cars work with that but Plymouth had there own way of doing the procedure.
CTUATOR CALIBRATION
Mode, Blend and Zone (if equipped) door calibration compensates for mechanical variations in the actuators, HVAC control module and its linkages. In vehicle calibration can be entered from the control's front panel. If the REAR WIPE and INTERMITTENT LED's flash simultaneously when Ignition is cycled ON, the actuators have not been calibrated or during the previous calibration a failure occurred. Diagnostics will always occur during Calibration Diagnostic and Cooldown test.
DIAGNOSTICS
During the Actuator calibration, diagnostics are performed on the actuators and evaporator temperature Fin Sensor. Once diagnostics are completed the REAR WIPER and INTERMITTENT LED's will flash to indicate either a successful calibration or the appropriate fail code(s). At this time manual testing of the Blend, Mode and Driver (if equipped) potentiometers can be performed. If a failure is detected during Diagnostics a fault will be set in the control. When Ignition is cycled OFF and then ON or Diagnostics is aborted, the REAR WIPER and INTERMITTENT LED's will flash simultaneously showing that a failure has occurred. The control will not indicate the fail code, but only that a failure had occurred during the last diagnostics test. The only way to clear the failure codes is repeat the Calibration Diagnostic and Cooldown test, after all repairs are completed.
COOLDOWN TEST
This test has been designed for performance testing of the A/C system at the manufacturing facility. If the IWAC control module is replaced, the Cooldown test will occur during Calibration test. Cooldown will not occur on Heater Only units. During the Cooldown test the control will monitor the temperature of the Fin Sensor. The A/C system must be able to bring the evaporator temperature down a predetermined minimum amount in less than 2 minutes.
CALIBRATION / COOLDOWN LED DISPLAY CODES
Jan 7, 2019 at 5:29 PM
Seems quite involved procedure for a laymen. Thanks for answering my question.
Jan 7, 2019 at 5:54 PM
No problem.
Just follow the instructions.
Always glad to help.
Jan 7, 2019 at 6:02 PM
