Climate control
2004 CHEVROLET MONTE CARLO
136,000 MILES • 3.8L • FWD • AUTOMATIC
MISSYACW
  • 7 POSTS
When i turn the heat up, the fans don't push air out, they stay off. When I accelerate though, heat pushes out the vents, but the fans still don't turn on. The faster I go, the more air pushes out from the engine. Not a thermostat. Fuse? Fans? Blower motor? Wiring? I'm not sure but my passengers have definitely kicked that bottom panel down.
Feb 8, 2016 at 6:32 PM
SATURNTECH9
  • 30,869 POSTS
So you have a dual climate control or single one?The blower motor isn't working at all?Also do you have a multi meter to do some testing?
Feb 8, 2016 at 8:40 PM
MISSYACW
  • 7 POSTS
Not sure on the first, no one the second, and no but I can probably find one
Feb 8, 2016 at 10:35 PM
MISSYACW
  • 7 POSTS
Actually yes, dual control.
Feb 8, 2016 at 10:37 PM
SATURNTECH9
  • 30,869 POSTS
Alright find a multi meter and do you know how to use a multi meter?
Feb 9, 2016 at 6:06 AM
MISSYACW
  • 7 POSTS
Well Im sure I could get instructions
Feb 9, 2016 at 6:41 AM
MISSYACW
  • 7 POSTS
Well thats handy, thanks
Feb 16, 2016 at 7:04 PM
MISSYACW
  • 7 POSTS
So once i find it and learn how to use it, what do i do with it
MISSYACW
  • 7 POSTS
The blower fans decide sheb they want to work, which is quite often so im lucky but i like to fix my problems before they get worse
Feb 16, 2016 at 7:06 PM
SATURNTECH9
  • 30,869 POSTS
Have you tried to wiggle the connector to the blower motor with it running to see if it starts running or stops running?
Feb 16, 2016 at 8:56 PM
