Clicking when key turned in
2001 FORD RANGER
130,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
JON LEGER
What is this piece here? It clicks when engine turned in. If removed I can short it between the top and bottom to get engine to start. Check engine light flashes at same rate of clicking.
Mar 31, 2018 at 12:09 PM
WRENCHTECH
  • 20,761 POSTS
I do not see any picture.
Mar 31, 2018 at 3:31 PM
JON LEGER
Figured out the part. Idle control valve, replaced it and it still just clicks over and over pretty quickly. Trying to pinpoint what the issue now.
Apr 1, 2018 at 8:29 AM
WRENCHTECH
  • 20,761 POSTS
What issue do you have? Is it just the noise? Is it idling okay?
Have you read the stored codes? What are the code numbers?
Apr 1, 2018 at 8:31 AM
JON LEGER
Truck will not start unless I take the part off and hold the valve in open position for a little while. Once I am able to get it started truck runs just fine. I have not been able to get the truck into town to read codes. There is not a check engine light once running. Seems like one of the circuits is having issues fully closing or opening initially.
Apr 1, 2018 at 9:20 AM
WRENCHTECH
  • 20,761 POSTS
Wait a minute... your check engine light is flashing before the truck is running?
That would likely mean there is an issue with the ASD relay or its socket.
Apr 1, 2018 at 12:57 PM
