Once my ignition clicks off there is a clicking noise?
2010 RENAULT MASTERS
200,000 MILES
1969ANDY
  • 7 POSTS
Once my ignition clicks off, I get a clicking noise from dash and needles move slightly. i have just had a starter and ignition barrel replaced, it wasn't doing it before. Any advice would be appreciated.
Sep 22, 2022 at 3:05 AM
Thanks for the video, it helps. This sounds like the battery is no good. To be sure let's turn the headlights on for 5 minutes and see if they stay bright. This guide can help us, and I have included a generic guide on how to change the battery out correctly:
and
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Please go over these guides and report back.
Sep 22, 2022 at 10:13 AM
1969ANDY
  • 7 POSTS
Thanks for your reply, I'll give it a try.
Sep 22, 2022 at 11:50 AM
Please let me know what happens.
Sep 23, 2022 at 11:47 AM
1969ANDY
  • 7 POSTS
I tried the battery this evening and it's okay.
Sep 23, 2022 at 11:54 AM
Are the battery cables clean and tight?
This guide can help:
Please go over this guide and report back.
Sep 24, 2022 at 10:07 AM
1969ANDY
  • 7 POSTS
I put it on the machine I've got, it wasn't showing any faults and cables are tight and clean on battery, if I sit in the van, lock then unlock it stops, but then it locks the doors it's self after a couple of minutes.
Sep 26, 2022 at 2:39 AM
It sounds like the BCM is going out or the instrument cluster itself. Has this car had any water damage? When they did the code read did, they do a CAN scan?
This is easy to do, and it goes over all of the systems in the car. Check out this guide:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Sep 26, 2022 at 5:23 PM
