clicking in the steering wheel again.
2010 NISSAN ROGUE
73,000 MILES • 4 CYL • AWD • AUTOMATIC
CED_1987
2010 Nissan rogue sl awd.
clicking noise from the steering column when turning all the time. cold weather makes it worse but you can hear it all the time. steering angle sensor assy has been replaced 2 times and the clicking will go away for a yr then come back.
Jan 10, 2014 at 11:04 AM
MHPAUTOS
  • 31,937 POSTS
See if any codes are set first, and get the steering checked out for any slack in steering shaft and all mechanical connections are ok, the sensor may be picking up a mechanical problem and it may not be the actual sensor.
Jan 14, 2014 at 3:50 PM
