very steady clicking coming from behind my steering wheel area?
2011 HYUNDAI SONATA
156,000 MILES • 4 CYL • AUTOMATIC
TIPJONES
  • 4 POSTS
There is a very steady clicking coming from behind my steering wheel area, near the dashboard. It can be as much as three to four clicks per second but about two to three clicks per second 65% of the time. It went away for a while, but it seems to have started up again since it got cooler in the area recently.
Oct 3, 2022 at 9:23 PM
TIPJONES
  • 4 POSTS
Clicking/Noise heard here.
Oct 3, 2022 at 9:27 PM
Thanks for the videos they help. this noise is caused by the blend door actuator which has had the gear stripped out, which is common. Here are the locations of the actuators so you can check it out, put you had on each one while the noise is occurring, and you can find the one that needs replacement. My guess is it will be the driver side mode actuator because it is right in the area the noise is being generated in. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Oct 4, 2022 at 9:56 AM
TIPJONES
  • 4 POSTS
Thank you! Is it something that should be fixed right away, given the longevity of the issue?
Oct 13, 2022 at 9:36 AM
Does everything in the car seem to work okay, no warning lights? If it's okay with not warning lights you should be okay.
Oct 13, 2022 at 3:08 PM
TIPJONES
  • 4 POSTS
Yes, it’s only the radio that went out almost a year ago and the starter was also giving me issues but that was recently fixed several months back.
Oct 13, 2022 at 4:04 PM
Yep, you should be good then. replace the actuator when you are ready.
Oct 15, 2022 at 11:45 AM
