Okay. The trunk is making me think we have a leak somewhere from the center of the vehicle or further back.
Do you have rust on or in either wheel wheel area of the rear wheels? I circled the location in the picture attached.
If there is no rust then we need to start water testing the vehicle. The best way to do this is remove the carpets (you need to dry them anyway) so that you can see when the water is running in.
Start with the trunk. Clearly everything should be closed and then just use a hose and start strategically spraying the vehicle down so that you know where you are spraying when the water comes in. It would be easier if you have two people. One on the inside watching for water coming in. If not, then you will need to spray water in one area for about 5 minutes and then check inside the vehicle for water.
Continuing moving around the car until you find the place that water runs in, then you can start narrowing down the area. Let me know what questions you have. Thanks
Mar 8, 2020 at 4:54 PM
