Clarity suspension issues
2015 JEEP GRAND CHEROKEE
32,000 MILES • 4WD
AETIENNE
  • 11 POSTS
Hi! I went to get an inspection and the guy pointed this out to me and I can’t remember what he wanted me to know. Any way you may be able to tell from this photo?
Thank you!
Aug 5, 2019 at 5:39 PM
Good evening,
I would love to help but the photo did not upload.
Can you try it again?
Aug 5, 2019 at 5:43 PM
STEVE W.
  • 15,113 POSTS
I'm sorry, your image didn't load properly, would you please try again. Thank you
Aug 5, 2019 at 5:44 PM
AETIENNE
  • 11 POSTS
I tried again and it says successful, hopefully it worked.
Aug 5, 2019 at 5:46 PM
Did he tell you the arm needs to be replaced or just the bushing?
Aug 5, 2019 at 5:49 PM
AETIENNE
  • 11 POSTS
That is the thing, I can’t remember. He told me to take picture but I don’t remember what he said. smh
Aug 5, 2019 at 5:53 PM
Call him back and ask him what he wants you to do. There does not seem to be any damage from what I see in the picture.
Aug 5, 2019 at 5:56 PM
AETIENNE
  • 11 POSTS
Okay, thanks so much!!
Aug 5, 2019 at 5:57 PM
You are welcome.
Keep us updated.
Aug 5, 2019 at 6:08 PM
STEVE W.
  • 15,113 POSTS
It would depend on which part. The arm looks okay, but the shock looks like it is covered in oil which may mean he was saying it needed replacement because it has leaked. Rotated the picture and circled the part. If this doesn't have the adjustable air ride suspension that shock isn't hard to replace, but I would replace both sides as they do change in damping as they age and a matched new pair is better than having a worn one and a new one. Changing them involves jacking up the Jeep, putting stands under the truck to hold it, remove the wheel/tires from both sides. Now remove the plastic trim in the wheel well so you can get to the upper mount. Remove the two bolts on top, then the lower one through the arm. The upper mount gets transferred to the new shock. Then you reverse the process to bolt the replacement in.
Aug 5, 2019 at 8:56 PM
AETIENNE
  • 11 POSTS
Going to look into this ASAP! Thank you!
Aug 5, 2019 at 10:40 PM
