removed cylinder head and have oil sitting on top of piston head is this normal, engine was overheating.
Jun 30, 2009 at 3:07 PM
DAVE H
CERTIFIED EXPERT
Hello .. thanks for the donation .. much appreciated
you may have a had a bad cylinder headgasket .. this was causing the overheating and allowing oil/water into the piston chamber's .. have the head pressure tested while off the vehicle to be sure it is ok (not warped/cracked) then replace with a new gasket set !!
hope this helps
