2004 Other Citroen Models Low pressure fuel pump
2004 CITROEN
BRISTAR182
Engine Mechanical problem
2004 Other Citroen Models Two Wheel Drive Manual
I have a picasso
recently i had a new low pressure fuel pump installed but i have been having problems with the car since.
the day i got it back i turned off the ignition took the key out then 5 seconds later the engine stopped running
The fault code keeps coming up for the pump
Im getting ghost fuel readings.
in your experience am i having these problems due to the garage not replacing the pump properly is it more likely to be another problem?
Sep 6, 2009 at 7:58 AM
DAVE H
  • 13,384 POSTS
I suspect the pump was installed incorrectly .. what are the fault codes showing !!
Sep 7, 2009 at 3:50 AM
