I have pulled all the pulleys and removed all the bolts from the water pump, but it appears as if there is one bolt remaining, however the head is not exposed, it must be on the back side. The water pump is paired with a aluminum back that won't pry off without removing that screw or bolt. I don't know how to get to that screw or bolt. i hope i don't have to remove the whole intake manifold to get to it.
Can anyone help me figure out how to remove the water pump.
This is a 97 dodge caravan, 3.0 L engine.
Thanks
Thanks
Jan 12, 2006 at 10:28 PM
