battery drain
CHRYSLER VAN
LESDOVE
1996 caravan -battery is dead after 2 days. pulled all fuses and still drains. bcm?
Feb 8, 2007 at 9:29 PM
GARFIELD
  • 197 POSTS
First thing I would recommend would be to have the battery checked at a local auto parts store. You just may have a battery that is starting to go bad.
Feb 9, 2007 at 5:15 AM
[quote:ca1c820cc5="lesdove"]1996 caravan -battery is dead after 2 days. pulled all fuses and still drains. bcm?[/quote:ca1c820cc5]
Get a voltmeter put it on 12vdc-now put black lead to negative and red lead probe on top of the battery in different places, anything over 0.01 reading needs cleaning-self drainage.
If you pulled all the fuses and its still there-try disconnecting the battery feed to the alternator and connectors-see what happens to the drainage.
HTH Good Luck
Feb 9, 2007 at 6:17 AM
