2003 Chrysler Van no fire - p0700 edbII fault code
2003 CHRYSLER VAN
88,000 MILES • 4 CYL • FWD • AUTOMATIC
ROYGIN
my van just stopped running all of the sudden. The code reader gave me a code of p0700 which is a transmission control system malfunction. I have no spark coming from the ignition coil. I replaced the coil and checked all fuses. still no fire. I am stuck. Is there a safety that would cut power from the ecm? what should i try next?
Aug 4, 2009 at 11:26 PM
Do you have power on the brown and white wire at the coil and injectors? If so check and test the cam and crankshaft sensors, no power at the brown and white test the ASD relay it powers both the coil and injectors.
Aug 5, 2009 at 1:41 AM
