The engine has developed a cold starting problem. When cold, the engine turns over as normal but is hard starting. While cranking it over, it sort of fires but will not run. After about 3 or 4 times of cranking it over, it will fire up, run rough for a few seconds and then run fine. Once it is warm, it starts right off as normal. It runs good under power as normal. Only when it is a cold start does it require several tries of getting it to start before it will run. I am not touching the throttle at all, just turning the key.
Dec 9, 2009 at 1:44 PM
